Author Topic: Turbo problems  (Read 2369 times)
Offline Teknik SuperSport
  • Team Teknik
  • American Made
Turbo problems
« on: 04:00AM 01/13/2004 »
Ok so my SS is put away for the winter so that means that my 87 Chrysler lebaron comes out. Well it has a stock turbo and i started to play with it and i put a homemade boost controler on it. The problem is that when the turbo starts pullin hard (about 3500-4500rpm) it cuts out  then pulls  kinda like a studder over and over. and it only does it at full throttle. any ideas? My buddy has the same setup in his 88 dodge shadow and it works for him.. WTF?
p
100% Natural
Re:Turbo problems
« Reply #1 on: 11:14AM 01/13/2004 »
there could be a boost leak somewhere. get the system pressure tested.
Re:Turbo problems
« Reply #2 on: 12:05PM 01/13/2004 »
could it be a leaky BOV? Just a guess.
Re:Turbo problems
« Reply #3 on: 04:43PM 01/13/2004 »
Sounds like it could be a boost leak...check your vacuum lines and all of that stuff.
Offline MiSs LaCiE
  • sexiest on the site
  • Gender: Female
    • myspace page
Re:Turbo problems
« Reply #4 on: 10:09AM 01/14/2004 »
I was having that same problem with my Eclipse and it ended up that my boost was leaking
  • Team Teknik
  • American Made
Re:Turbo problems
« Reply #5 on: 04:10PM 01/14/2004 »
Would that cause the whole car to shut down? cuz thats how it is but the car dont die, but it comes close too.
p
100% Natural
Offline MiSs LaCiE
  • Gender: Female
    • myspace page
Re:Turbo problems
« Reply #6 on: 06:34PM 01/14/2004 »
mine would only cut out for a second...but it never came close to shutting off...so I dunno
Re:Turbo problems
« Reply #7 on: 03:11PM 01/15/2004 »
a big boost leak would cause the car to studder and feel like it was stalling because there wouldn't be enough air for the ammount of fuel being burned. check your vacuum lines and whatever you're using as the boost controller.  my friend put a home made BC on his impulse and had to fix it a couple times because of the same problem.
« Last Edit: 03:12PM 01/15/2004 by BtownCivic »
Offline sunflashx
Re:Turbo problems
« Reply #8 on: 12:58PM 01/16/2004 »
Boost leaks are also bad for turbo efficiency.  It has to work harder to supply the set amount of pressure.
Even if it isn't the cause of your problem you would do well to check for leaks.
The preferable way is to clamp a device like this onto the inlet of the turbos compressor housing and use a air compressor.
http://www.machv.com/macvleaktes.html
Offline spinz4
Re:Turbo problems
« Reply #9 on: 01:26PM 01/16/2004 »
I have that device!
Blue b a s t a r d
  • Team Teknik
  • American Made
Re:Turbo problems
« Reply #10 on: 12:30AM 01/17/2004 »
How many air lines are there? i hook it up to the one off the WG right? Sorry im not very smart with turbos, i got a V8 lol.
p
100% Natural
Offline next genracing
Re:Turbo problems
« Reply #11 on: 03:10PM 02/11/2004 »
i would put money on it being a fuel cut to limit the car from overboosting.  i know that mitsu's have them to get it to work properly i bet you will need to get something to clamp the voltage to the the ecu from map or maf.  there are numerous products out there that will cure this they are usually pretty pricy though.
also it could be a boost leak i doubt it though it would do it most of the time if there was a leak that was significant enough to make the car feel like it turns off.
Danny
