Just want to share some intresting fact that I have learned about my wrx.
First off the Ej20 is an amazing motor. I love owning a turbo car, add AWD to that...... The only weak link in the car is the tranny. As long as you dont drop the clutch the tranny will last and all will be good. As far as engine upgrades go I could be at the 300hp mark in no time. It is actually very simple to upgrade and tune the wrx. Most of you know about Cobb Tuning next door to Modern. They are amazing to say the least. They have a complete tuning package that includes 10 fuel maps that you can automatically change to as you upgrade your car. It is called access port and it is only 555.00. You plug it into you OBDII port and select the map you want, wait for it to load, and then un-plug it. Simple as that
Stage 1 map. This is a stock everything map. It basically smooths out your fuel map and removes a 1st gear boost limitation.
Stage 2 is getting close to 300 crank HP it adds 54 HP at the wheels with the addition of a catless up-pipe, and turbo back exhuast.
VF30,34 maps. These are upgraded turbo maps. The VF30 and 34 turbos are capable of creating more boost than the stock turbo. So after the stage 2 mods have been done you can order a set of STI injectors a VF34 turbo (VF34 is the one I am going to get) and an upgraded fuel pump. This will get me to 300+ hp
It also has a valet map, an economy map (for running <91 octane, and is capable of storing custom maps as well.
Very simple to upgrade. This is as far as I will take this car. After I am done with the WRX, When I get enough cash the integra will finally get some love by way of B18C5.
