Author Topic: Engine Bearings #Speed Tech/Phase One#  (Read 1685 times)
Offline SCxMaster
  • Featured Member
« on: 11:59PM 12/02/2003 »
I saw my attorney today and he wanted me to find out if it's impossible to put the wrong bearings in a motor.  And also about running out of oil http://www.eliterides.com/forums/index.php?board=3;action=display;threadid=879;start=9;boardseen
I need to get PROFESSIONAL statements for court but all your opinions/experiences will help.
Re:Engine Bearings #Speed Tech/Phase One#
« Reply #1 on: 12:54PM 12/03/2003 »
It is very possible to put the wrong bearings in while building a motor. They should be measured for proper clearance before they are installed. If you dont have the correct bearings your motor will tear itself apart.
Offline SCxMaster
  • Featured Member
« Reply #2 on: 01:30PM 12/03/2003 »
Yeah, that's what happened to my car.  But in his statement he said it's "impossible" to install the wrong bearings.  He put 3000GT bearings in my motor.   I guess since both our cars motors are 6g72 motors he figured it would work.
« Reply #3 on: 02:28PM 12/03/2003 »
Here is an email from Larry Widmer. He works for endyn
Spun bearings if they are too tight, no oil pressure if they're too loose.
The reason Honda engines work so well from the factory is because Honda
spends so much time making sure bearing clearances are right on the money.
We spend 4-6 hours checking bearing clearances on engines we assemble...
----- Original Message -----
To: <staff@theoldone.com>
Sent: Wednesday, December 03, 2003 2:12 PM
Subject: main bearings
What would be some problems with a motor built with improperly sized
bearings? I appreciate your time answering this question.
Thanks
Corey
EliteRides.com
Even if they are the same motor the bearings must be sized in order to work correctly. Any engine builder should know this. Every engine is different even if they are the same motor type.
« Reply #4 on: 03:09PM 12/03/2003 »
This guy must be a complete idiot...you need to have the correct size no matter what the car is.  Sounds like he is already admitting fault if he put in the 3000 gt bearings.
Offline SCxMaster
  • Featured Member
« Reply #5 on: 04:32PM 12/03/2003 »
When it first broke he told me that the person he ordered them from sent the 3000GT bearings and that was the problem.  Now that I'm taking him to court he's saying he didn't put the wrong bearings in.
« Reply #6 on: 01:31PM 12/04/2003 »
What ever he is saying is a bunch of crap. It all boils down to the fact that he didnt size the bearings correctly and he should pay for your new motor.
Offline sunflashx
« Reply #7 on: 11:17AM 12/09/2003 »
There are about 10 different main bearing part numbers for 3g eclipses.  Depends on your production date and specific clearances.  Roughly 5 available sizes per vehicle production range.  Some of the bearings interchange between production ranges, some don't.
Rod bearings are all the same on 3g eclipses.
Main bearings come in a variety of sizes for the 3000gt
Rod bearings for 3000gt cars come in a variety of sizes.
As far as I can tell none of the Mitsubishi factory part numbers interchange between the 3000gt and 3g eclipse.
Rod bearings are more versatile, you can resize the big end of the rod to match the bearing and crank journals.
Main bearings would require a line hone.  It's not cost effective to do over just matching the right bearings, and the block would have to be out of the car.  No in-car rebuild.
If during the rebuild you use ARP main studs or rod bolts you would have to line hone/resize the rods because the mains and rods get pulled out of round by the differing clamping force.
Also, I believe that 1995 and newer Mitsu stuff uses non-reusable main bolts, they generally stretch when you torque them to spec.  Most say to not reuse them, but you can inspect them and reuse them if they are not severly stretched.  Reusing a bolt that was stretched out of spec could lead to abnormal wear issues.  2g eclipses are this way, I'm assuming all newer mitsu stuff is the same.
Offline Kanzen
  • OmegaPer4mance
« Reply #8 on: 08:24AM 12/10/2003 »
Sorry but this is none of my business and will not comment on this subject....
"You know what I think and im telling you man, If you give people respect and POLITELY tell them what you need to say then I am sure you won't come off as such a f u c k head!  "    --Quoted by Oskar--
Offline Alaskan Assassin
  • SQUAD 752
« Reply #9 on: 09:19AM 01/02/2004 »
you already did.
1989 Nissan 240SX
1998 Acura Integra Type-R #406 CW -SOLD-
Offline zula99si
  • Limitless in our Pursuit for Performance
    • www.rmjmotorsport.com
« Reply #10 on: 05:40PM 01/02/2004 »
sounds like you have a good case man, out here we measure and check everything over many times, just to sure, hey its called doing it correctly.
"Limitless in Our Pursuit of Performance"
Check out my Shop?s site. www.rmjmotorsport.com
Offline Staats
  • Moderator
« Reply #11 on: 11:15PM 01/05/2004 »
Yeah you get a few whops all over the country that do it half a s s and then they charge you for 5 hours work when they did 2 1/2 at the best thats why you have to trust your mechanic. but good luck hope you get your cash back
A fear of weapons is a sign of retarded sexual and emotional maturity- Freud
