Author Topic: Built, 89 Mustang LX. (331 Stroker/TKO600/Nitrous) 10's 1/4  (Read 1603 times)
Offline thumper_302
For Sale 1989 Ford Mustang LX.
This is a consistant 10:80 1/4 mile car with a 150 shot of nitrous, a consistant 11:50 car on the motor.
I am offering the car in two different forms:
Unpainted $8000.00 obo
Complete repaint $10,000.00 obo
Engine is a 1968 block bored and stroked to 331,  forged crank, H-Beam rods, Ross forged 10:1, Total Seal rings, ported Canfeild heads, Parker funnel web intake, 1.6 comp cam roller rockers, ARP main and head studs, Romac sfi balancer,  sfi flywheel with Spec stage 3 clutch, custom ground Comp Cams Nitrous cam, Demon 750 carb, MSD 6al and MSD SS coil,  BBK 1.75 long tube s/s headers, BBK s/s x pipe with flowmasters, BG 400 fuel pump with voltage reducer with a switch for street or race, Edelbrock Performer RPM NOS kit 100 to 250 HP,  2 BG fuel reg, sheet metal valve covers with vent tubes going to vented catch can, NOS purge kit.
Transmission is a TKO 2 that was rebuilt with TKO 600 parts with short throw shifter and aluminum drive shaft.The rear end is a 8.8 with 33 spline Moser axles spooled 4:10's with c-clip eliminator and gurdle. Adjustable uppers and lowers control arms, qa1 adutable shocks with 2 air bags.
Suspension: Front end has tubular A arms and K member, Flaming River Rack and adjustable coilovers.  Rear end has aluminum lower control arms with adjustable spring mounts, adustable upper control arms, drag launch spring with two air bags.
Fuel System: Complete custom 10 AN fuel line from the tank to the regulator.
Body:  Clear 6 piece head lights, Hardwood 4 in. lift off cowl hood.  Paint needs to be redone due to the clear cracking from age.
Interior:  New black carpet, 2 Kirky seats, 10 point custom cage by Voodoo Chaises, Auto Meter tach with shift light,  Auto Meter oil and temp gauges, power windows & power door locks, tilt steering.
Front end:  Tubular K Member with Tubular A Arms, Wilwood front brakes, Flaming River rack & pinion, and adjusable coilovers.
Rims and Tires:  New Greg Weld Dragster rims 15X3.5 and 15X8, front tires are 165's very good shape, backs have 26X10X15 M/T slicks
Buyer is responsible for shipping arrangements but I will assist in any way possible. I will deliver up to 500 mile for an addintional cost.
Pinks All Out Gainsville, FL 2008
Wilwood front brakes.
Car has power windows and locks, tilt steering, hatch and gas tank door release from glove box. Head liner is in place but needs to be cleaned or replaced. If car sells for $10K I will replace the head liner.
These car is extremly FAST! Should only be drive by an experienced driver.
You can contact me via phone at 915-309-0703 or by e-mail at ofcmelendez@yahoo.com
Car is located in El Paso, Tx.
