Author Topic: Civic SI Sedan Concept  (Read 1891 times)
Offline Teknik_DC2
  • Team Teknik
  • Superchargers Suck!!!!!!!!!!
« on: 01:20AM 03/03/2006 »
The Civic Si Sedan Concept provides strong hints of the styling and performance for a production Civic Si Sedan scheduled to go on sale this fall, marking the first time that "Si" performance has become available in the Civic Sedan. Similar to the recently introduced Civic Si Coupe, the production Civic Si Sedan will serve as another performance leader for the Civic line-up with a 197-horsepower, 16-valve, DOHC i-VTEC engine with an 8,000 rpm redline, mated to a close-ratio, 6-speed manual transmission. Helping to put all that power to the ground is a helical-type, limited slip differential for improved traction and cornering performance.
The Civic Si Sedan Concept features custom 18-inch cast aluminum alloy wheels, 225/40ZR18 high-performance tires, and 4-wheel disc brakes with large cross-drilled brake rotors and 4-piston Brembo calipers.
"The Civic Si Sedan Concept demonstrates how the high-performance attributes of the Civic Si Coupe can be directly applied to the functionality of a sedan," said John Mendel, senior vice president of American Honda.
A production vehicle based on the Civic Si Sedan Concept will go on sale this fall. The 2007 Civic Si Sedan will mark a further evolution of Civic Si's sixth generation alongside the Civic Si Coupe - and will be the first time a Civic Si is available in two body styles. The Civic Si first appeared in 1986 with subsequent Civic Si models appearing in 1989, 1992, 1999 and 2002.
The Civic Si Concept (coupe version) made its debut at the 2005 Chicago Auto Show, preceding the introduction of the all-new 2006 Civic Si, Civic Hybrid, Civic Sedan and Civic Coupe. The Civic Si Coupe and Civic Si Sedan will both complement the Civic lineup with features designed to appeal to true enthusiasts seeking a high level of performance and value.
2000 Integra Type R | 1993 Del Sol S | 2007 Mazda3
Re: Civic SI Sedan Concept
« Reply #1 on: 07:30AM 03/03/2006 »
I like it... other than the mini ironing board on the trunk.
Offline andrew65
« Reply #2 on: 11:04AM 12/11/2008 »
2007 Honda Civic Mugen Si Sedan
Honda revealed a prototype Civic Mugen Si Sedan prepared by legendary Honda tuner Mugen equipped with a high performance suspension, forged aluminum wheels, aerodynamic body styling and a sport exhaust system at the 2006 Specialty Equipment Market Association (SEMA) show. Planned for production in a limited quantity of 500 units a year, the Civic Mugen Si will be available at U.S. Honda dealers starting in spring 2007 with a manufacturer's suggested retail price of less than $30,000 and a full factory warranty.
"Enthusiasts have equated the name Mugen with JDM Honda performance for decades, and with the introduction of the Civic Si Sedan, the time is right for the two companies to once again join forces," said John Mendel, senior vice president of American Honda. "A Mugen-tuned vehicle available directly from the factory provides the ultimate level of performance, quality and refinement in a specially-tuned car."
The track tuned suspension, tested at the Twin Ring Motegi racing circuit in Japan, lowers the vehicle by 0.6 inches with aggressive spring and damper tuning for enhanced handling performance while still maintaining a high level of ride comfort. Compared to the stock Civic Si Sedan, front and rear damping force (both bump and rebound) was increased between 8- and 24-percent (the rate varies depending on condition). Lightweight 16.7-pound 18x7.5-inch forged aluminum wheels (27 percent lighter than the stock 17x7 alloy wheel) and high-grip BFGoodrich g-Force KDW 215/40 ZR18 summer tires help to further create Mugen's rewarding and well-balanced handling performance character.
*By S2K1*Maybe we should just go check out your website and see for ourselves what you recommend?!? Hmm...good idea. Nice try. Links removed.
« Last Edit: 12:19PM 12/11/2008 by S2K1 »
