Author Topic: JG Engine Dynamics Turbo Grind H23 Cams  (Read 5985 times)
Offline Jeffrey
  • Lightning Thrower
    • Welcome To My Hell
« on: 02:59AM 03/01/2006 »
Product
Short Review
Stock cams modifed for a boosted engine.
Good & Bad
Pros:
Very big gain at higher RPM ranges.  Made the engine sound a lot different too.
Cons:
Low end power suffers slightly.
Full Review
It's the difference between night and day on a Turbo H23 Prelude. Besides the lengthy install/tune and idle compensation, it's awesome.
When it comes to cars, you have three options: Fast, Cheap, and Reliable. And you can only pick two.
Offline Jeffrey
  • Lightning Thrower
Re: JG Engine Dynamics Turbo Grind H23 Cams
« Reply #1 on: 05:01PM 03/01/2006 »
There...I did it.
Offline ashiq2009
  • Feedback +0/-1
« Reply #2 on: 11:14AM 06/26/2009 »
 for high-boost turbo applications or EXTREME all motor applications. ..... Two cam grinds with identical lift & duration numbers can perform very .... Endyn, RLZ Engineering, DH Racing, R&D, Gude, and JG Engine Dynamics. .... The most common option for an H22 is to use the 95mm crankshaft from the H23 or F22
Links removed. Thank you, come again.
