*Old thread, but i'm bored off my a
ss*
H23/VTEC hybrid - No problems
Learn how to run an oil line CORRECTLY, use the
H23 gasket, re-use the H23 Belt/Tensioner, block the hole in the bottom of the head CORRECTLY, lower your rev limit, and learn how to tune
H23/VTEC - Problems
REV LIMIT - Your bottom end was designed to handle a certain RPM, the H22 was designed to handle more. Most people rev to 8100 on a motor that was designed to rev to 6500/7500, this causes premature ring failure.
Dowel Pins - It is NOT necessary to re-drill your head to accept the dowel pin, just use ARP head studs or line the head up with your head bolts.
Blocking the oil line in the bottom of the head - Tap the head, then put a threaded plug in it, problem solved.
Head gasket - Non-VTEC
Oil feed line - 1/8" NPT line from sending unit to 1/8" NPT plug behind distributor. DO NOT DRILL A NEW HOLE, THERE'S ALREADY THREE PRE-DRILLED/CAPPED HOLES FROM HONDA.
They are when they're stroked and blown, but then again, I guess that's not a B18 anymore
I wasn't recommending one, just stating what I saw at HIN two years ago...
Obviously it's not the best choice for a lude, or else it would be done more often...
But an H22 in an Integra/Civic is a far worse idea (IMO) than a B18C5 in a 'lude.
Unless your goal is to go in a straight line
I say pump your car full of nitrous so you have have an excuse to get the motor you want
B18C5 is an overrated high compression motor that only useless slugs and bandwagoners get. There's a few problems with fitting one in a prelude, one being the engine bay is just to fawking big that you'd have to somehow make mounts to center the engine, then after that's done, you have to get some extended axles, which nobody makes, then you have to figure out how to mount rod linkage instead of the prelude/accord cable linkage. Then comes the wiring, the C5 has a totally different harness than the H23, so you'd have to take the two and make one out of it, run wires for VTEC, knock, and injectors, etc.
Then comes the getting the car to move part... with the exteded axles, the heavier body, and less amount of torque, how would this boat move?
ahhhh yessss.... it's stroked and blown. Stroked to what 92mm? 95mm? either way, it's stroked, that means the redline will have to be lowered from 8500 to somewhere in the 7500 range to accommodate the longer stroke and increased friction on the pistons. Then comes the blower... the blower? Jackson Racing and Vortech, the only two ITR blowers available, since we're fully built, I guess we should be running around 9psi....
Stroked motor, high compression, 9psi, ping ping ping BOOM!
Let's stop making up stories here though.
