Author Topic: which turbo for 2000 Civic EX?  (Read 2110 times)
« on: 11:23AM 04/25/2004 »
Everyone talks up Drag as quality so I'm considering that.  I also get fatty discounts with GReddy so that's a plus.
Suggestions?  Other brands, etc.?
Offline MitzuRida
  • Smilie Whore
Re:which turbo for 2000 Civic EX?
« Reply #1 on: 11:36AM 04/25/2004 »
ive been in a couple with greddy i like the greddy ones, i heard drag is good, i just like the kit greddy gives you minus the filter lol but either would be good whats the price diff between them
91 crx hf-sohc and turboed almost done
LIFES A b i t c h...THATS WHY I FLIRT WITH DEATH...
« Reply #2 on: 01:02PM 04/25/2004 »
Hmmm... a few hundred more for Drag on retail vs. retail.  But, with the discounts I get on GReddy it would be about a $1000 cheaper for me to get GReddy.
Offline blitz21
« Reply #3 on: 05:29PM 04/25/2004 »
i think drag...well take into consideration the following
Drag pro......t3/t4 turbo...big intercooler....lots of power ..great fitments
drag con.....no instructions(if you are smart-dosn't matter)...missing a few little things you will have to have like the oil return line hookups...you will have use a custom hose...also the oil pan you will have to weld a part on too it.
greddy pro...electronic fuel management/injectors...great fitment
greddy con... really small turbo and piping...you wanna run 13's this is not the kit unless you plan on doing internal motor upgrades
base line.....greddy retail.....$2959 with NO intercooler add $ 900 hundred more for intercooler
Drag retail ....$3000 everything
you decide........
Dont think a muffler,intake, and some stickers make you fast!
« Reply #4 on: 07:30PM 04/25/2004 »
uhh, the GReddy kit doesnt cost anywhere near 2,959, and DRAG isnt 3,000.
first off, the GReddy kit for 96-00 Civic EX is about 1,950, and the DRAG kit is around $2,600-$2,800. i dont know what kinda deals you get with GReddy, but i imagine it would cost MUCH cheaper than DRAG.
the GReddy also comes with a 19T turbo, which is basically a larger version of the 15G that's included in the 92-95 kit. its good for at least 18lbs of boost, and i doubt you'll even run more than 10-12 unless you build your motor. the new kits also come with the E-manage that's pre-tuned for your car, and can be re-tuned anytime you want, and the 96-00 includes a set of 310cc injectors.
aslo, kits like DRAG and MaxRev are not bolt on, they require modification of charge pipes, etc... the GReddy kit bolts right on and fits the first time. and you can get the type 34 FMIC kit for your car and that will bolt right on also.
MaxRev is much more customizable than GReddy or DRAG, you can select the trim and polish of the turbo, polish of the manifold/downpipe, and you can choose from a few different engine management systems. the charge pipes are DIY, so you'll have to cut them yourself or have a shop cut/weld them. both MaxRev and DRAG come with T3/T4 turbo's and external wastegates, where the GReddy kits have mitsubishi internally wastegated turbos.
i personally think you should go for the GReddy kit since you already get a discount on it, and it also comes with injectors and fuel management, where DRAG doesn't include either. but you should also look into MaxRev, they're about the same cost as DRAG but have much more options.
Offline PedroCesar
  • Turbo4Life
« Reply #5 on: 10:00PM 04/25/2004 »
you can always upgrade your turbo,wastegate and manifold later
and if you want my two cents i would go with the Greddy for the fuel management and the discounts
Japan was awesome. But now it's time to try out Virgina.
Offline MitzuRida
  • Smilie Whore
« Reply #6 on: 10:18PM 04/25/2004 »
GREDDY GREDDY GREDDY
and you also have to get the greddy type s bov oh do i miss mine  :'(
Offline Tyler
  • ER's pikchure taker
    • TCGphoto.com
« Reply #7 on: 11:34PM 04/25/2004 »
16G.  Run 6psi.  Change your internals, run 17psi.
\Ma*lef"ic\, a. Doing mischief; causing harm or evil; hurtful
« Reply #8 on: 05:45PM 04/26/2004 »
The Greddy is the only one that will pass emissions...since you live in Salt Lake County legally.
« Reply #9 on: 02:57PM 04/27/2004 »
Are Rev Hard kits good?  Awesome deal on e-Bay right now.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33742&item=2476122598&rd=1
Quote
this is an amazing turbo kit my shop was closed down have a few in stock
it fits
94-01 integra
92-00 civic
for b series motor
brand new in box
NEW! Stage: 2
Use: Street/Track
Part #: RHSTGII
MSRP: $3,599.00 (New Pricing)
Boost Level: 7psi
Injector Size: Stock
Horsepower/Torque: +120 / 285 ft/lbs
Rev Hard Cast Iron Manifold
 High Volume Fuel Pump
Rev Hard T3/T04E Hybrid Turbo(eff. to 450hp)
 Silicone Hoses & Clamps
Rev Hard Intercooler 28x6.5x3
 Steel Braided -3 Oil Line
NEW Turbo Smart 7psi. (TS-SEMA's Best Product for 2002)
 Oil Return Line
Vortech Blow Off Valve
 High Pressure Fuel Line
2.25" Aluminized Mandrel Bent Piping
 High Pressure Silicon Hose
2.5" Downpipe
 Necessary Vacuum Tee's
Check Valves
 Necessary Vacuum Lines
Optional Upgrades:
2.5" Aluminum Upper Charge Pipe for 94-01 Integras / 92-00 Civics +$150
Air Filter Adapter for 92-00 Civics
« Reply #10 on: 03:53PM 04/27/2004 »
Rev hard makes really good kits, but their stage one, which is about the same as maxrev or drag, retails at like 3,500-4,000, so i'd stay away from them unless you're blingin'
« Reply #11 on: 05:56PM 04/27/2004 »
Be very careful getting a turbo kit from ebay...I was burned twice.
« Reply #12 on: 10:28AM 04/30/2004 »
How so?  Dang't, that sucks to hear.  There's two right now that I am considering buying.
« Reply #13 on: 12:24PM 04/30/2004 »
Get the Greddy kit. After looking at the two kits they are both shady. Just make the call and get the Greddy. Then add an intercooler later on.
